how do you remove rocker arms out of a vtec head. i have a b16a2 and ive disassembled the entire engine accept for the rocker arms. if anyone could help that would be great thanks.
the allen bolts on the side of the head abd u need to pull the oil orfices and pull out the shaft that the rocker arms are on. But the helms gets into detail on it.
Like he said! Kinda. Keep all of the rock arm sets seperate and together. Make sure everything goes back in the way it came out. The Helms is a must for torques, although you could probably bribe someone for them. (20ft/lbs for the 10 inner bolts, 7.2ft/lbs for the outer four... tighten from the middle out alternating sides.) Also, you'll need a pair of twelve mm bolts to screw into the shafts to pull them out with, once you remove the sealing bolts.
