Hey guys, any ideas on removing spray paint from rear tails? As long as it doesn't corrode the plastic (as I'm sure the original color is BEHIND the plastic), it should be fine. Any suggestions?
Yeah, a WHILE back, someone on here suggested using stained glass spray paint on tailights, and it ended up ok, but I want the original look back.
So yeah, I did it, and I used crylon stained glass paint, along with some clear coat.
I would try just normal rubbing alcohol. Maybe nail polish remover. Try it on a little area, maybe the corner first.
try using carbeurator cleaner.. my friend was cleanin some stains off his car and some went onto his tail lights which we also painted with stained glass, and it came off. so u see this nice orange spot on his tail lights
EV4530 on Sep/05/02 said:
laquer thinner is what i use and it wont melt the light
get it at home depot
This is the best way to go. It should gently remove the paint :)
