anyone know how to remove the glovebox from the hinges so I could pull it out? which screws to undo?
thanks!
Its pretty much common sense. Look under where the glovebox is connected to the dash. There is like 2 screws on each side. Then Remove 1 screw from where the hinge thing attach to the glove box. After that just lift and its done.
yea, so those five screws should do it..
reason I want to do it is because i'm mounting a switch in that general area.. and I need to get behind the glovebox in order to mount it more securely. Don't worry, the box will go back on!
