I have a 94 4 door integra. on the door panels, there is a patch for better lack of words of fabric the same as the seats. How do you remove these so you can reupholster those spots where interior fabric already exists??
Mike
Is it just clips that hold it in or what?? When i take the door panel off, there is no access to this area of the door panel?? I want to make sure not to screw it up so it will go back in correctly...
That's totally different Insane8
For Integra, the fabric is "stick" on the door panel, use a flat screwdriver, put it into the gap, u should able to pull out some part, then pull out the fabric slowly, in this way, less fabric will stick on the panel, after u pull the fabric out, u will see a lot fabric still stick on the panel, they looks like grass, use a screwdriver to scratch them out, then use "spraymount" to stick yr new fabric back~
P.S.
Don't forget to use the fabric u pull out as a draft to cut the new one!!!
is the part that has the fabric removable tho ?? won't that spray stickmount stuff make the cloth all crusty once it's absorbed into the fabric ?
So they section just pops out and then pops right back in?? I am wondering how it is held in there?? Clips, screws, pins etc...
