I noticed that when i pulled the throttle like thing in the cruise control off to de-install it .. some tension was lost in the normal throttle .. If I remove the CC will i still have normal throttle or should i reset my timing?
Also How do you get the cord out of the hole between the two nuts and is it possible to disconnect from the firewall?
