has anyone every removes the wheel studs for their integras. i have read the how to remove it but the book shows that the spinel come right on off but it is not that easy. Thanks for all help
Yes, i had to change broken studs a couple times and the rotor comes off easy but the hub don't..i took it to a tire shop and they used a special puller to pull it off, cost about 50$.
The only way to purchase a 5-bolt rotor is to purchase the ITR rotor, which will not allow you to use the stock caliper. Complicate that will needing 5 lug wheels.
It would be possible to have a new rotor drilled for 5 studs, but it's pointless IMO.
