1 - 2 of 2 Posts
What parts are commonly replaced when a engine is rebuilt to stock proportions? Like if I had a high milage car and wanted to rebuild it to ensure reliability(not performance). Thanks
upper gasket kit change out to refresh head $200
resurface head $40
deck resurface and hone block $60
new piston ring set $150
main bearings, rod bearings, thrust washer $200
pan gasket $20
oil pump $200
water pump $75
timing belt $60
belt tensioner $60
new accessory belts $60
new cap, rotor, wires, plugs, fuel filter $100
new coolant, oil, filter, air filter $75
clutch kit $300
resurface flywheel/new $50/$200
pull motor, rebuild, reinstall 40 hours about $1500
would be a good price for labor from a tech on the
side.
Put $3000 aside and you should be fine.
1 - 2 of 2 Posts
