I'm curious to know if anyone has found a solid fix for the infamous rear wheel well rusting that occurs on many hondas. Integras come with a tight fitting rubber seal inside the rear wheel well that seem almost water tight but I've heard from some folk that you should remove it as it gathers sand, grit and water over time and will speed up the rusting problem. Has anyone had the problem on their 96+ Integra and if so did you remove the seal?
