Bigger aftermarket rear swaybarcodenamezero on Feb/19/04 said:your car comes with a facotry rear sway bar...
???????Louse76 on Feb/19/04 said:But you can't turn fast enough to make use of a bigger rear sway when you're lowered 2.5".
No really, I'm not joking. Maybe if you had some DAMN STIFF springs you could make a quick turn assuming the surface was perfectly flat. It's just unfunctional to lower 2.5" and still go for performance.justin_dailey on Feb/19/04 said:He was making a joke that the car would be so low that it would scrape if he made fast turns due to body roll.
I do think it would help considering the bar increases spring rates. But he doesn't have much suspension travel! So it would at best be of little help.Louse76 on Feb/20/04 said:Quote: justin_dailey on Feb/19/04He was making a joke that the car would be so low that it would scrape if he made fast turns due to body roll. No really, I'm not joking. Maybe if you had some DAMN STIFF springs you could make a quick turn assuming the surface was perfectly flat. It's just unfunctional to lower 2.5" and still go for performance.
