Hey integra fam so this is whats goong on i have a 98 integra ls with an auto b18b1
Now starting last monday morning i was driving on the highway and my car shut off and i rolled to the shoulder and after waiting a few seconds i turned the key and the engine turned over but no start so i waited another minute and i gave it another go and it started back up and i got all way to my destination with no issues and even returned home with no issues later that night same thing i was driving for a while and then another random shut off waited a few and it started back up no issues , since then its been the same pattern even after changing the fuel pump and fuel filter which was just changed today i started her up let her get warmed up and took it for a drive after about 10 minutes she shut off i tapped the distributor with a wrench and she started up and then shut off then i waited a few again she started up and i drove maybe 5 feet she shut off again i waited again she started and now i just made it back to my house, now im starting to suspect the dizzy only because last week when i checked it the screw holding the rotor in place worked its way out and the rotor flipped around and i guess i was driving it like that for awhile. Anyone have any ideas what i can do, if it is the distributor i have a spare d16y8 dizzy from a 96 civic would that be compatible in any way??
how old is the main relay? id try that from the civic just to test it. the dizzy from single cam wont work, has to be b series.
Okay im going to have to buy a main relay i dont have the one from the civic but i took the distributor apart and cleaned it up it was greasy and grimey on the inside and i was able to drive to the gas station and back without shutting down i will check the main relay tomorrow tho just incase because i know its never that easy lol
Basically used a voltmeter and a wiring diagram, found out where the power was getting cutoff from the car and cut out the part of the alarm that was responsible for that. Then soldered a wire between the cut wires...
My car would shutoff but the dash lights were still on, then suddenly the car would fire back up again. It happend a few more times then finally wouldn't start at all...
Discussion Starter #7
Okay integra homies i managed to fix the issue turns out the ICM in my dizzy went bad i replaced it with the one from my d16y8 dizzy and added some thermal grease and shes good as new
