1 - 1 of 1 Posts
Noticing a somewhat intermittent issue on my 1994 LS the radio (aftermarket but wired and grounded correctly) and DC outlet occasionally take a little while to come on. Sometimes about 15 seconds, sometimes several minutes.
All fuses are good, no lights are out when this happens, the clock works (so not the backup fuse under the hood), additionally the lighting behind the dials and the lighting for the climate control works while the radio and outlet are temporarily out.
Both the radio and outlet are either on together or off together, never just one.
I would guess this would be an issue with either the accessory or accessory delay relay.
Does anyone know what might the exact issue could be and if it seems to be a relay where these are located and how they can be tested?
1 - 1 of 1 Posts
