1 - 2 of 2 Posts
Looking for 1987 Radiator grommets:
60785-SD2-000 Lower.
19021-PG6-000 Upper
Dealer discontinued
Google search nor eBay worked.
Any other places?
Check junk yard. Even grommets from other makes and models may work. If you can't find it there, I suggest you use hoses of various diameters. Cut 1/2" sections, insert smaller diameter hose inside larger and repeat it again (if necessary) to achieve proper size (for the bottom grommets).
1 - 2 of 2 Posts
