1 - 9 of 9 Posts
i have a 2k gsr, which is making noise from the right radiator fan(facing the front of the car) when it is turned on. anyone have any clue?
did you check for obstructions? loose cables and such? maybe a twig found it's way in there? maybe a squirrel is living in your radiator fans =)
well, first i found a tooth of a deer,then some beef jerky..but yeah i found a squirrel in there running on the fans...thank god its just a squirell..i took it out and cooked it southern styleee...
anyways, when the fan turns on at idle, it sounds loud and abnormal..i checked for any obstructions..but werent any..so i was just checking to see if anyone here had similar problems..
just spray some lubricant into the spinning bearing and it'll clear up just fine.
i also had this problem. turned out it was loose screws. try that. though the noise is still there, but only at a minimum. and im gonna try spraying some lubricant on it pretty soon, see if that helps.
O i had that noise before sorta like a squirrel screaming right? LOL well the fan is loose so check that. I brought it to a shop than BAM!!!!!!!!
yeah make sure all your screws are tight had this prob with my civic a lil work with a 10 mil and a screwdriver you can fix anything on a teg. not really but ya know what i mean.
I've started to have this problem too. It is the A/C fan and only screeches sometimes. It seems like it happens more often when it is hotter out (85+ degrees). What do I need to lubricate, and which screws do you think could be loose? Thanks in advance!
1 - 9 of 9 Posts
