i'm sure this has been discussed before but i couldn't find it on any recent posts. I have 205/40ZR/17 Nitto 555 Extremes. In one place on the tire it says "never exceed 40psi" and on another place on the tire it says "never exceed 50psi". It almost seems like my tires are a little bit flat, but i put them all at around 37 or 38psi. I was wondering what should I put the psi at?
yeah, i run mine around 32 PSI the sides squish for more surface contact
If you're not using the stock size, the stock pressure isn't what you should be using.
Exactly. If you are only concerned about handling (and ride quality and tire life don't matter) then check out my article on tire pressure here.
Otherwise you want the tire to ride on the full patch of tread, but not on the shoulder of the tire. Its going to be different for every tire.
