sup guys,
my friend just got a b16 swapped in his DA. it was running fine up until today. It started to miss so we parked it and started to take a look at it. We figured out that the problem is cylinder number 1. Its getting spark,has good compression,getting fuel,but when we take the plug out of the motor,its drenched in fuel. Then on top of that when the motor is running,and you disconnect the wire from the plug,nothing happends. Normally the car would start to run like **** if you take the wire off the plug with it running,but when we do it to cylinder 1 nothing happends. Again,getting spark,fuel,compression is fine. what could be going on.
PS the car is only throwing code 21,because the vtec solenoid isnt hooked up,and the knock sensor isnt wired.
