if you are putting them on yourself... good luck. make sure you have an angle grinder and blow torch on hand... or an acetyln torch. on my 95, i had to cut the rear shocks out with a grinder and replace the lower bushings. hope yours aren't as bad, but it might be a good idea to do the bushings while you have everything taken off. what shocks are you using?? good luck!
