I am having a problem with my Audiobahn powered sub. I installed it and it seems to be working fine, then randomly it will stop playing low to medium volume. Here are the thing I have checked when it stops playing.
-It is receiving power when it stops playing. The blue power light remains on, and all fuses are intact.
-I used a spare speaker to tap into the signal going into the sub at the speaker harness that goes into the sub itself. (I am using speaker level inputs). I did this each time it stopped playing and each time the test
speaker played . So the audio signal is ok too.
Here is the weird part. The way I get it to start playing again is to plug an IPOD directly into the RCA inputs. Then I hear bass from the IPOD. When I turn the stereo back on, then the sub is playing fine again. This method to get it playing again worked 100% of the time.
Somehow it seems that a RCA direct in kick starts it into working again.
I am pretty sure the wiring to the sub is fine as plugging in the IPOD wouldn't fix the problem if it was wiring.
Could the sub be defective? Or is there something else I should check?
