21 - 40 of 68 Posts
block work: (b18c-r)
stock crank (micropolished and balanced w/ CTR crank pulley)
all ARP bolts
OEM bearings
OEM gaskets
stock ITR rods
stock 81mm ITR (jdm) pistons
CTR crank pulley
head: (b16a)
mugen 2 layer head gasket
P&Ped
skunk2 valvetrain
skunk2 stg 1 cams
skunk2 cam gears
Hondata Intake mainfold gasket
skunk2 IM (ported to 70mm)
OEM ITR Throttle Body ported to 66mm
Toda timing belt
tranny:
fidanza aluminum flywheel
*edit* clutchmasters fx400 6 puck
ARP flywheel, and clutch bolts
*edit*omnipower CMC
JDM ITR tranny
energy suspension shift bushings
skunk2 shifter and knob
fuel and management:
walboro 255 lph
*edit*RC 310cc injectors
AEM Fuel Rail (not needed but i just re-used it from last build)
hondata s200
exhaust:
mugen header
Omni power test pipe
T1R Spl (thanks tomm!)
204whp/137 tq.
I dont have the graph that has these numbers...but i got one that is close so it'll have to do
http://static.photobucket.com/player.swf?file=http://vid64.photobucket.com/albums/h177/95gsrb16/100_0965.flv
360 at 16psi
took out most the irrelevant stuff from my list of parts
Transmission (GSR tranny)
Competition Stage 4 clutch
ACT streetlite flywheel
OBX Limited slip differential
Bottom end (JDM GSR B18C block)
Benson sleeved 84mm
CP 9.8cr 84mm pistons
Manley turbo tuff gsr connecting rods
OEM GSR crank
Moroso baffled oil pan
Head (USDM GSR)
Skunk2 pro Intake Manifold
Hondata Intake Manifold gasket
home made oil catch can
Skunk2 Tuner valve springs
Skunk2 Tuner 1 cams
Skunk2 Pro cam gears
Turbo (custom build)
Garrett gt2871r with ATP T3 housing
Spoolin quick4ac
Spoolin closed loop 3" Stainless Steel dump tube
Spoolin FMIC piping
Tial 50mm bov
Ebay "400hp" Intercooler
Tial 38mm wastegate
GM 3 bar map sensor
Thermal Research 3" Stainless Steel catback
Electronics/other:
Delphi 880cc injectors (peak and hold)
Neptune RTP hardware (installed in obd1 ecu)
OBD2 -> OBD1 ecu harness
OEM P28 OBD1 ECU- chipped
NGK spark plugs (BKR7E) (gapped at .028")
Walbro 255 fuel pump kit
Greddy profec spec 2 Electronic Boost Controller
all ARP bolts
OEM bearings
OEM gaskets
stock ITR rods
CTR crank pulley
head: (b16a)
P&Ped
skunk2 valvetrain
skunk2 stg 1 cams
skunk2 cam gears
Toda timing belt
tranny:
fidanza 3-2 clutch
JDM ITR tranny
walboro 255 lph
RC 370cc injectors (little big but I got a great deal on them)
exhaust:
mugen header
204whp/137 tq.
I will have to say thats pretty impressive with those cams in the car. Have you thought about going something a little beefier? Great numbers though!
Bottom End
B18C1 Block
Hot-tanked & Honed
Wiseco 9.6:1 Pistons
Eagle H-Beam Rods
OEM GSR Crank
ARP Rod Bolts
ARP Cylinder Head Bolts
Cylinder Head
B18C1 Head
Type-R Cams (00-01 Spec)
Skunk2 Pro Series Valve Springs
Skunk2 Titanium Retainers
Skunk2 Cam Gears
Stock Valves
Edelbrock Victor X Intake Manifold
Turbo
Synapse T3 Ramhorn w/AC
Garrett T3/T04E .57 trim
Tial 38mm Wastegate
Tial 50mm BOV
Synapse 2.5in Charge Piping
Synapse 3in Stainless Steel Down Pipe
Garrett Core Intercooler 24x6.3x3
PWM Boost Solenoid
Apexi WS2 80mm Universal Muffler
Fuel
255LPH Walbro Fuel Pump
Precision 880cc Fuel Injectors (Ball & Seat)
Precision OBD-1 Injector Clips
Tuning/Electronics
OBD1 P06 ECU
Demon Tuning Board
Neptune Software
AEM Wideband UEGO Controller w/ Bosch Sensor
GM 3 Bar Map Sensor
TunerView II
TunerView Rd-1
Transmission
Stock GSR Trans
Competion Clutches Sprung 6-Puck Stage-4 Clutch
Power Levels - Tuned
438whp/303wtq @ 19psi
Needless to say, the turbo is completely maxed out. Not to bad though for the size of it.
thanks man, yeah im trying to save up for some skunk2 pro 1 cams and a tri-y header.
on a side note, those numbers do not include actual cam timing...because we never adjusted them, when i got it tuned noone could believe it made those numbers....
all ARP bolts
OEM bearings
OEM gaskets
stock ITR rods
CTR crank pulley
head: (b16a)
P&Ped
skunk2 valvetrain
skunk2 stg 1 cams
skunk2 cam gears
Toda timing belt
tranny:
fidanza 3-2 clutch
JDM ITR tranny
walboro 255 lph
exhaust:
mugen header
204whp/137 tq.
Where did this setup make peak tq?
1995 GSR, I/H/E Set-up on Mild tune.
First run: 158.8hp, 120.54 tq
Second run: 160.01 hp @ 7800rpm, 123.63 tq @ 5800rpm, 90% torque available from 2800-7200rpm
Conditions: ~98°F, ~30% humidity
Set-up:
Comptech Icebox Intake w/ K&N Filter
DC 4-2-1 Ceramic Header
RSR Exmag exahust
Highflow cat
Apexi VAFC
i just recently dynoed my car today... so i dont have graph pic on my computer yet
all stock except
DC short shifter
cheap CAI with K&N filter
i got 146.9 whp and 114wtq
and its 1998 gsr with 130,000 miles
teggy999 on Jul/23/10 said:
Stock K24A1 head(OEM VTEC Killer)
Stock K24A2 block
RCrew Header
RBC Intake Manifold
Skunk2 Cams
Love looking at this graph. Must be so much fun to drive. I won't derail this thread, but I'd love to know how you put that power down, lol.
BTW, What kind of Skunk2 cams does it have?
100% stock k20a2
3" CAI
Skunk2 knockoff header
3" exhaust
RBC
Z1 cams
100 shot dry single nozzle
900 bottle psi. Later retuned on the street at 1000psi
I will be posting my direct port setup tomorrow
Bottom End:
Stock sleeved GSR
Stock GSR Crank
81.5mm SRP pistons 8.8:1 CR
Eagle H beam rods
ACL race bearings
Head:
Stock GSR head
Stock valves
ITR valve springs
Stock GSR cams
Turbo Setup:
Precision SC6152E turbo
Ramhorn Manifold
3" DP to 3" Vibrant TPV exhaust
SRE intercooler piping
Godspeed 500 hp Intercooler
Tial 38mm WG
Greddy knock off BOV
Edelbrock Victor X IM
Professional Products 68mm TB
Tuned on Neptune by Chad @ MKC made 419whp and 269 ft/lbs tq @ 20 psi on 92 octane pump gas
Trans:
- Stock open diff LS tranny
Block:
- 85mm GE GodZilla sleeved B18C5
- GE oil squirter delete plugs
- ITR crank
- ITR water pump
- ITR oil pump
- Eagle H-beam rods with ARP 2000 bolts
- Wiseco 8.8-9:1 CR Pistons
- ACL race bearings
Head:
- Refurbished B17 stock port head
- Blox valve springs
- Blox Type-C cams
- AEM cam gears
- Supertech Ti retainers
- Victor-X IM 68mm
- 68mm Blox TB
Fuel:
- Walbro 255lph intank pump
- AEM fuel rail
- B&M FPR
- Delphi 1000cc injectors
Turbo Setup:
- Full-Race ramhorn
- Full-Race T3/T67HO turbo
- 44mm TiAL WG w/open dump tube
- 50mm TiAL BOV
- 31x12x3 FMIC
- 1st gen SRE IC piping
- Blox MBC
- Blox 4" velocity stack
Exhaust:
- Spoolin' Performance 3" V-band DP
- 3" DP-back piping
- 3" Vibrant black oval muffler
Misc:
- Spoolin' Performance -3AN oil feed line kit
- Gates Racing T-belt
- Blox oil adapter "sandwich" plate
- Omni 3bar MAP
- F1Racing stg. 4 clutch kit
- Half-size dual core aluminum radiator with pusher slim fan
- B&R Valvecover breather kit
- Traction bars
Tuned 1/20/2010 @ RedZone - 91 octane pump gas, and 17 PSI later:
476whp/318trq
Then decided to put on a cool-air extension pipe on the turbo with the v-stack on just to see what it makes on the final pull.
480whp/330trq (didn't ask for a printout)
Vid of that last pull
http://www.youtube.com/watch?v=eqavl-Xk3Y4
Now it's my Honda Challange H1 build
Stock K24A2 Bottom
Stock CRV head
RBC IM
K24A2 cams(OEM VTEC Killer)
R-Crew Header/3" exhaust.
Custom intake w/Turbonetics 4" velocity stack.
247/192 N/A @ 5280ft
wonder why using the stock CRV head instead of the A2 one..
bigger intake valve and ports? the stock one was damaged and this was a replacement?
sorry for the questions but I am such a noob with K series.. :eek:
I bought this car as is. But here's the setup and my dyno numbers from today.
Engine:
- Original (rebuilt) LS head w/ mild port and polish
- Original LS block sleeved by Benson and bored to 2.0L
- OEM head gasket bored to 2.0L
- ARP Head Studs
- 9:1 CP Pistons
- Pauter Rods
- ACR Race bearings
- ARP Rod studs
- Precision 525cc injectors
Turbo Stuff:
- Turbonetics Log manifold
- GT3251 Journal Bearing Turbocharger
- Custom 3" Down pipe
- 3" high-flow cat
- Thermal 3" Exhaust
- Garret 500hp Intercooler
- 38mm Tial Wastegate
- Tial BOV
- Boost by Gear/RPM solenoid
- Koyo Half Sized double core radiator
- Walbro 255 fuel pump
Dynoed at 301.86 whp 287.25 wtq 3/26/2011
The stock CRV head has identical ports and valves to the K20A/K20A2 heads. But it doesn't have reliefs for Lost Motion Assembly's. So I ran an OEM VTEC Killer setup similar to aznasinine(above).
Thanks! Stage 3's. It's mostly a track ***** now so I run 15x8 949's and 225/50-15 Hoosier R6's. Honestly, it's a little stressful to drive. I've got an S2000 CR that's much more pleasant simply because I have so much more time to relax between turns, and brakes much more predictably. Once I fix the brake situation though, it should be much better. But there's not another FWD car that's even within 4 seconds of my best, so it is quick.
'98 Integra RS
Old Dyno (Non-vtec):
Mods: I/H/E/hi-flo cat, engine mount inserts - 128whp
New Dyno (Swapped vtec head on same car)
Mods:
B16a head
B16a manifold
B16 stock cams I believe
ARP headstuds and rod bolts
ACL race bearings
B16a transmission
Stage 1 clutch
176whp
Used the same dyno both times. I also included old non-vtec and new ls-vtec numbers as well as overlayed both to make it easier to see the gains.
21 - 40 of 68 Posts
