I was thinking about getting a Sony CDX M-730 deck and some Infinity Reference 605cs components for the front. The h/u is supposed to be 23.5 watts rms. Anyone have any opinions about the deck or the components? Here's the links for both. Thanks all.
http://www.xplodsony.com/products/?CATEGORY=CD&MD=CDX-M730
http://www.infinitysystems.com/caraudio/product.asp?ProdId='REF605CS'&Ser=REF&Cat=COS
Not a big fan of the newer Sony decks (no complaints on their older models though)...I'd look into something else there.
There's no question that your system would sound much better, cleaner, etc. w/a separate amp. However, if you don't want to mess w/an amp, then look at the Pioneer decks...or any other brand that uses a MOSFET amp (not sure who else is off the top of my head). That type of solid state amp usually sounds the best.
As for the speakers...I've heard mixed things. Listen to them yourself and compare them w/others, base your decision on that.
General Features
MOSFET 50W x 4
XM Satellite Radio Ready
Controls optional GEX-P900XM or GEX-FM903XM Satellite Radio tuners (as External unit)
8-character display for XM Radio text (no scroll)
Card Remote
Rotary Volume Control (Pop-Up)
EEQ Performance Chip
3-Band Parametric Equalizer (Adjustable Level, Frequency and Q Factor)
Easy EQ (EEQ) switches 5 Factory, 2 User EQ Presets (Super Bass, Powerful, Natural, Vocal, Flat, Custom 1 and Custom 2)
Source Custom EQ Memory (Independent Custom Memory for each source)
Selectable Loudness Control (Low/Mid/High/Off)
SFEQ (Sound Focus EQ)
Additional Independent Bass / Treble Control for Front / Rear
Subwoofer Crossover
Selectable LPF (Low Pass Filter) (50/80/125Hz, -18dB/oct)
Sub-Out Level (-12dB to +12dB) and Phase Control
IP-Bus System Control
MCD Control
TV Tuner Control
Auxiliary Input (CD-RB10 or CD-RB20 required)
2 External Unit Control
S.L.A. (Source Level Adjustment)
Selectable Fader Control
RCA Preouts (x2 pair, Front & Rear or Front & Sub) (2V)
Organic EL Display (128 x 33 pixel)
Full-motion 3D graphic animations including
2 screensavers (Dolphins, Racing)
2 Level Meters
4 background animations
Clock Display and Off (Text-only) modes
16-character text display capability
Adjustable brightness level (16-mode)
Cellular Mute Capability (CD-CM1 required)
Clock
Compact Disc
Track Scan/Pause/Repeat/Random Play
Audible Fast-Forward/Reverse
Playback Compatible with Digital CD-R and CD-RW
Disc Title Memory (48 Discs)
CD Text
AGC (Automatic Gain Control)
8x oversampling
3-beam laser pick-up
1-bit D/A Converter
Anti-shock mechanism
Chassis
DIN Mountable
Detachable Face (faceplate carrying case included)
Flap Face
Radio
Supertuner III
24-Station/6-Button (18FM / 6AM) Presets
BSM (Best Station Memory)
Up/Down Seek with Selectable Local Seek Tuning
i was lookin' at those same speakers, and i have the deh-p6400 also, think it'd be good to get an external amp? i believe the components run 90 watts rms, so i doubt if my 23 watts or whatever can push those well enough...
also to the people that have the 6400, have you tried switching the rear preouts to subwoofer? if so, how are the crossovers and controls working? thanks...
