Blazinqwickly on Oct/10/07 said:
Well I will be honest alot of shops around here will tell you to go oem with the bushings because #1. They can be a bit more of a pain in your ass to install. #2. you still get squeeking eventually. #3. your going to feel alot of bumps and shaking in the steering responce from the road so if it's a daily driver ither do it or dont. when I did the rear trailing arms on my 00 I went oem again and they still feel just fine . But then again I also drive a 4dr.
I've got the whole ES kit and installed the rear trailing arm bushings at the same time.
The ride is more a LITTLE harder but not that much.
You can really see the difference than rubber.. it doesn't have memory.
Kinda like floating, better response too
I'm on stock GSR Shock/Spring still but i would recommend them regardless.
BTW: keep posted of the install
