1 - 15 of 15 Posts
hey, i have a 94 integra rs with a gsr swap, i recently started hearing this clicking noise like a deck of cards being shuffles from the right front wheel area, it only happens when i am accelerating so its not just a piece of plastic or something rubbing against the wheel, any thoughts of what this could be, any suggestions are greatly appreciated, thanks
fender lining maybe.
The Enforcer!
cv joints?
axle?
definately probably cv joints/axles/boot or axle. every integra has or had that problem. mine does! axles, radiator, and power antenna are the main things that go wrong on integras
take off the axles or somethign off ur 95 and put em on ur new one
how do iu fix this problem, do i have to get new axles?
It's your motor mounts.
Remove your motor and check under it.
Otherwise, you should also disassemble your transmission or take apart your fuel injector and have a lookie.
I'm a qualified internet mechanic. I learnted all I know from messaje boreds.
Or you could just take it to a mechanic.
...buuuut that would be too easy.
Let's keep plugging away guys. What do you think?
AC fan? ECU?
i dont think thise kinda of responses are tolerated around here speechless..what your doing right now is a typical thing i see happening on other boards...
There's a point to all this.
It's called - seek professional help.
up untill your post i think there were completely resonable ideas and things to look at that the members contributed...not everyone who knows /has experience can jump to a thread with there input and even then theuy cant be 100 percent correct as there reading the problem,not diagnosing the car...anyway i"ll let the mods do there job..
edit..nice post deletion..
Yeah, i got off my soapbox.
For the record, I think my ideas were just as reasonable.
Anyways, all sarcasm aside, I think it could also be an exhaust leak. But hey, I'm just as clueless as anyone else. The possibilities are too vague to be diagnosed accurately over the internet without anyone seeing your car.
u call this reasonable?
Discussion Starter · #15 ·
thanks a lot guys, after someone posted and suggested it was my axles i took it to my mechanic and verified it, now i'm looking for a new axle, thanks guys
1 - 15 of 15 Posts
