· Registered
My plug wires got removed (the wires that wun from the distributer to the top of manifold cover....and when the person that removed them went to put them back on they did it incorrectly and now the fireing order is all screwed up...so what is the firing order???
· Registered
1,3,4,2
· Registered
The firing order isn't the issue, just re-connect the wires to the distributor correctly. When you connect the wires back up to the distributor, connect them like so
34
12
The wires should be marked with their respective cylinder number as well be the correct length to reach their cylinders like mentioned before.
