I finally bought my block that I will be using for my turbo setup. I came across an LS block with Crower rods,Arias pistons, Golden Eagle "Godzilla" Sleeves (83 mm), original misc like oil pan, bearings, crank, block girdle..new oil pump and water pump. A kid before me had it and was running crappy fuel management. The motor has about 2k miles on it.. and due to the crappy fuel management one of the pistons got burned up. Everything else is in good shape.I need to replace the one piston setup my LS Vtec combo install my LSD and new clutch. The LSD i plan to be a Quaife.. haven't decided 1 way 1.5 or 2way, any suggestions on a clutch? Oh I got this motor for 1600 from a friend.. I was told it should support a crap load of boost and would have cost about 3k to build. All comments and suggestions are wanted, I plan to use this daily and doubt the motor will ever see more than 25lbs of boost.
