Does anyone know how to get the brake/accelerator pedal assembly out? Do I have to lower the stearing colum to remove the pedals and if so would it be ok to do so? It's an auto btw.
You don't need to remove the whole thing. The clutch pedal is mounted separately...
...and all you need to do is swap the brake pedal arm from the manual pedal set into your car....there is no need for pulling the whole thing. I have done two conversions by myself and it is the easiest way.
Look at how the arm itself can be removed, near the pivot point, just take it out and take out the auto brake arm the same way.
You have to adjust the switch that is touching the pedal arm, it's too close to the pedal, back it off until the lights go out and only turn on when you press the pedal.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Team Integra Forums
