1 - 20 of 23 Posts
..any one have a pic of where it is on a gsr? I think ive been trying to take the wrong thing off.
good idea. Ive been getting alot of blowback out of my engine. the guy at midas said its a dirty PCV valve. All i have to figure out now is...where exactly it is located. I guess this is where Mr.Helm makes his money. :)
i actually heard somewhere that it is right where the breather hose connects to the valve cover..right under that little clamp thing.
no pics, but its either on top of ntake manifold under fuel rail, or under the manifold near the rear of engine(closer to tranny)... hope this helps.
well, i think ive found it..under the I/M but how the hell do it get it out!? My hand sure as hell dosent fit down there.
unfortunately, i believe you have to reach from underneath unless you can fir your arm from driver side...sorry.
just be sure your not pulling out the oil pressure sending unit right above the oil filter...youll know 'cause you have to unscrew the send unit though..
Hmm, I haven't actually payed attention to the PCV location on a GS-R so it's possible. Strange that the Helms doesn't say it's in any different location either.
But if it is underneath the IM jack up the car and crawl under. I'm not sure if the IM bracket will be in your way though.
well i just jacked up ther car..and your right..theres a bracket in the way. any ideas? i thought this was a 5 min switch..yet this is my 2nd day trying to figure it out
Discussion Starter · #19 ·
aight..well i got it out finally..but the pcv valve is still stuck on the hose..how the hell do i get it off? it wont budge, i took the metal clamp pff already its still stuck.
Damn my back is killing me... I just got done changing my PCV valve in my GSR. What a ***** and a half! It's almost impossible because its under the intake manifold. You have to reach around a bunch of hoses and you constantly scrape you hand on the throttle body. I'm glad I dont have to change it again for a good while! Time to lay down...
1 - 20 of 23 Posts
