Hey im about to buy a gsr block off a guy @ honda-tech but I dunno what all I need. I already have a gsr engine, but i'm tryin to build as much of a block as I can on the side.
Here is what he's offering:
windage tray
brand new main bolts
oil pump pickup
brand new flywheel side cover with rear main seal
girdle
part of the thermo housing (lower half)
the water tube between the water pump and thermo housing
itr oil cooler
mains
oil squirters
oil pan studs, bolts
windage tray studs
oil pump bolts
flywheel side cover bolts
knock sensor
crank
what of that do I actually need for a block build? (im not asking what else i'll need, just asking what I need off that list)
Discussion Starter · #2 ·
he's saying basically all i need is
block
crank
mains
main bolts
girdle
oil squirters
arp rod bolts
no he's just saying that's what i'll need out of what he has....i can figure out what else i'll need, im just building my block outside of my car for now, I have a stock gsr to drive and can pull parts from it if i have to when it goes in.
do i need all that stuff?
also I just got an offer for a bare type r block w/ a scoured cylinder wall (im sleeving anyway) what's the difference? will it be just as good for boost?
what about oil squirters? and what would be some pros and cons of getting an itr block?
