Ok, for about a month now, i have had the same problem many TIs have, crack in the radiator. So i went out and bought a replace ($80!). install went okay, but I am 100% sure that it is installed correctly. now...heres the problem. I was driving back to school, (it was about 50 degrees out and sunday, plus I have a black car) and the temp gauge rises. it was passed H for about 5-6 minutes cuz there was no exit on the highway for a while and stayed at H. so i pull over, dreading what i must do next, but i put my hand on my hood (a black hood out on a sunny day) and it is warm, not hot at all, just as if it were sitting outside, which it was. I drove the rest of the way, and still nothing is hot or overheating....soo...
here are the facts:
new radiator
no leaks at all (checked all hoses)
coolant level is good
is it the thermostat? if the thermostat is bad, wouldnt I REALLY be overheating??
could it be a temperature sensor?
water pump?
head gasket?
Im clueless, but happy the car wasnt actually overheating. Im thinking it is the tempertaure sensor b/c with the cracked radiator, teh temp gauge never got passed H, actually never reached H. plus when I got it looked at, the shop said it was def the crack in the radiator causes the engine to overheat..any ideas?
EDIT: sometimes when Im in neutral, the rpms will surge from 1k-2k and back down then 1k to 2k etc...whats this mean?
The Enforcer!
my car did the samething. my raditor cracked, changed the raditor adn it was still over heating. changed teh themorstat, problem fixed
yes the coolant level is fine
justyncredible--was your engine REALLY overheating after you installed the new radiator? or was it just the temp gauge rising...or do you not know?? thanx
sorry to bump, but i need to fix this problem by tom. Im a commuter and need my car...
