last night my 94 ls began dumping coolant from my belt side of the motor. i could hear boiling from over there, then saw coolant coming out. it was dark so i couldnt pinpoint a spot. i got some water and kept refilling it and nursing it home. about 1/2 mile from my house there was a jerk and the motor seemed to sieze up... i tore it open today and found a shredded timing belt was the cause for the siezing, but could this be linked to my water pump causing it to overheat? i bought a new thermostat, head gasket, and timing belt today and if necessary i will be getting a new water pump tomorrow. just wondered if these are related or what else should i check? there are no visible hose cracked and my radiator is in good shape... one more thing, when i was readding water into the radiator, the radiator wasnt even hot... it seems like it would be a water pump or thermostat. any help would be appreciated... this is my only car for work, so the sooner i get this running, the better... thanks
well, that sucks... thermostat is good... what is my best bet then? new motor or new head? this was an $1800 car a year ago, so im not wanting to put more than like $500 in it... what are my options now then?
well if your valves are bent then its going to prolly run you more then 500 bucks. IF you are lucky then when the t belt broke it might of stopped before anything touched but thats like 1 in a million chance of happening...good luck
