1 - 1 of 1 Posts
So my car is a for the most part stock 2001 integra with some aftermarket 15" rims. I am not fond of the rims and don't think they look as good as the factory blades do. I plan on running the current rims for winter times and am about to put winter tires on the car. Going to put some 195-55r15s for the winter. When spring comes back around I plan on having a new set of kicks ready for the car. My thought was to run a 205-50r15 tire. Will these fit the factory GSR Blades or should I get a wider rim? This car is my DD. I plan on running some factory type R springs to lower car and koni yellow shocks probably lowered to the max setting so maybe 1" to 1.5" total drop from factory. I would like to track my car next year at least once. Would a 205 be better than a 195 on a stock rim or would it be best on a wider rim? Also want to make sure this is not going to rub. 205 or 195 and if 205 what rim? Want to be able to run street and track with out issues.
1 - 1 of 1 Posts
