I just recently change my oil and ever since, then (2 days now) my engine kinda gives off a light oil smell. Sometimes I get it through the vents.
Now the weather has been nicer and I have been pushing the car more, so maybe that's the reason, but the car doesn't overheat and I have the correct amount of oil in the engine.
BTW I'm using Mobil 10w30 with a K&N oil filter. Also replaced the spark plugs with NGK Iridium ones.
Is it normal to get that light oil scent or do I have to check something over?
You may have dripped a bit on the header underneath the oil filter...???
Maybe make sure your oil filter is on tight and not dripping at all...
Thanks I'll double check that when I get home tonight.
I might just be paranoid since this is my first car and my first time doing an oil change.
Thanks again.
yea...usually just oil dripped on heat component then it will burn off, some time u can actually see white smoke comin out of ur hood, it will be gone after a couple of days....
Gordon
