when i do install my oil return line i am wondering what i should use. I see alot of people use steal braided (teflon center??) and rubber hosing. Which one would be better?
Also the oil resturn fitting (the part that bolts to your oil pan), where would i get this part? I see alot of people install it so it is pointing sideways. Wouldn't it be better to mount it so it is pointing up?
AND.....how would i connect the oil return lining to the fitting on the turbo and to the fitting on the oil pan? Hoseclamps??
Thanks
Dawson
edit: i also see alot of people talking about using AN fittings over brass, becuase the brass fitings usually break. Is this true? What are and where can i find "AN" fittings.
Thanks
Dawson
