This picture doesn't show the leak, since I took it before I noticed oil and engine dust collecting in this area. If you've had this type of leak before or know how to deal with it properly/accordingly, please reply. Thanks.
Click Here
The area inside the blue is where I have oil leaking. Does this have to do with the seal between my transmission and crankcase? Something around there...
How do you know its not the cam seal? its the only thing that makes sense.. either that or the valve cover gasket is leaking in that corner...
it might be your oil pan gasket its common with our cars, i had to replace my gsr's and my si's in the same month. but thank god i work at honda!
In that area the only things that could be leaking would be the cam seal or the valve cover. To me from where that is its the cam seal.
Are you sure its not the cam seal? Have you tried replacing it?
