1 - 11 of 11 Posts
I found this image, while doing a google search. Any known reasoning why it's better to mount verticle?
perhaps the inlet is on the top?????????
I would assume that this would be using gravity to help pull the oil through the lines.
If that's not it, I'm stumped......
-Fent, who is still trying to figure out where there would be room to mount an OC vertically on a G3 Teg.
I thought gsr's and r's had oil coolers stock. Beside the driver side headlight in the front. Isnt it mounted vertical?
You're thinking of the A/C condensor coil. Yes, the ITR does have an oil cooler, but it's nothing to the extent of the remote oil cooler I desire.
1 - 11 of 11 Posts
