Mac8008 on 08/June/2002 said:I tried to install the moroso can, but it was just too big. Everything else is sraight foward though.
here's where the Realtime boys put theirs...behind the driver's side headlight...
so that jaz catch can can be used. i simply remove the filter on top. stick a rubber grommet in the hole with a PCV valve on top and run the hose to somewhere on the breather tank on the engine?Michael Delaney on Aug/01/02 said:it won't pass emissions in ontario. Just hook up a PCV (Positive Crankcase Ventilation) valve from Honda and high pressure fuel tubing where the filter is located to the breather tank opening on the block when it's time to do your emissions and you should pass with flying colours.
