Well I got a set of JDM OEM fogs from PasswordJDM and they were used, didn't come with all the screws. My bumper was not ready for them, having plastic still there. I thouhgt I make an OEM install guide, there is already an aftermarket one but I figured it would help out anyone who needs some directions. Here it is.
First Itook off the front bumper.But don't make the same mistake I did by taking off these bolts. It took too long and I found out they didn't do anything at all.
For tools you'll need a razor blade, phillips, and in my case a screwdriver tool. But first you want to turn the bumper upside down and cut out the squares on the bottom corners of the bumper.
Next I had to go buy screws from Home Depot.
Youu want metric screws (8) 4mmx12mm and (8) 4mmx16mm with corresponding washers and nuts
Youu want to screw in 2 of the shorter ones into the sides, not the middle one
and on the other put the screws in and put on washer and nuts on backside of light.
Next take the cover and put it over the light and screw the longer bolts into the middle and the front.
Repeat on the other side, re-attach the front bumper. follow the directions on "Wiring the OEM foglight switch" under the articles section, and your all set to go.
