My car has Nuespeed Race Springs installed. I have a front Ingalls Camber Kit in my room, uninstalled, model 35720 with +1.25 to +3 degrees of adjustment with polyurethane bushings. I know I currently have negative camber. My question is, will the minimum +1.25 degrees of camber give me too much positive camber? Or should I get another camber kit with a lower initial minimum setting? I know camber should not be set at 0 degrees, due to performance problems. Is my current camber kit too much? I read that some negative camber is good. Also I'm not an autocrosser/racer, but occasionally do "straight line racing". So its more of me saving my tires for more street use. Thanks
