1 - 17 of 17 Posts
· Registered
i just noticed this noise yesterday. the noise is not there at higher speeds, but only at real low speeds like when i'm pulling into a parking spot. only when i'm applying the brakes, i hear this "tick, tick, tick" noise with each revolution of the wheels. can anyone tell me what this could be? again, at higher speeds, i don't notice it at all and the brakes seem to work fine. thanks.
· Registered
this thread is ressurrected... i have a ticking or clicking noise from my brakes when I both press and release the pedal. the noise is kind of like a rubbing/gripping noise with a tick or click associated with it... this noise occurs mostly when im going very slow or when the car is standing still. my mechanic says my brake pads are getting low, like change after winter low, but this has been going on for a couple months... anyone have any ideas?
· Registered
It probably is the brake pads, although they do usually make a screaching sound when they're low. The brakes might make a sound like that if your lugs aren't torqued correctly, which warps the rotor slightly. You're probably just at the beginning of the wear tab. Given that, you could probably wait out the winter, depending on how hard you brake. That screaching noise is annoying and embarrasing though.
· Registered
Rainman on Jan/13/03 said:
Is there a way to single out which one is the warped one?
take your wheels off... use your finger to press the brake pad against the rotor, and spin it. if you feel a wobble... you've got the warped one. warped rotors only matter if they are seriously messed up. usually it's just annoying to feel the pulsing in the pedal when you are braking. if you plan on racing, consider getting it fixed due to the slight loss of braking power. warped rotors will also wear your pads down quicker.
1 - 17 of 17 Posts
