1 - 2 of 2 Posts
Okay, so after hours of research and money spent on parts, I’m at a halt on diagnosing what may be wrong. I have a 93 1.8l integra with fuel issues. I’ve bipassed the pump on a constant hot toggle switch to the battery, I’ve just recently replaced the pressure regulator, fuel filter, tps and still no luck. It starts fine with starter fluid, gets fuel pressure no problem, but will not stay running. Any help would be good. All fuses, relays and voltage is okay.
Gets fuel, spark and air, but will not stay running if I use starter fluid.
Sounds to me like the injectors are not firing. You could pull the rail and (with a proper fixture) test that.
Best bet though is to follow the Helm manual troubleshooting section for fuel. It's very comprehensive and almost always pinpoints problems for no-start conditions.
1 - 2 of 2 Posts
