Hey, so I've been slowly wrenching at my teggy to get it running right, but now all of a sudden it just doesn't idle at all? It's like the IACV is not even plugged in. I'm not getting any CEL code though and I tested by unplugging it and starting the car and it came right on. I went ahead and bought a cleaned up oem refurbished one. The FITV has also been completely disassembled and cleaned recently, I don't think this would be the issue anyway bc my car doesn't have a fluctuating idle. The only other clue I have is that the car usually won't start unless I give it gas. I have put in a fuel relay, new fuel filter, and spark plugs along with the brand new IACV, also believe that I fixed the vacuum leak problem with a brand new brake booster vacuum check valve. Seems to run better with the new one, but still has a low idle as well (when it does idle). Can't really seem to find anything specifically like my situation on the forums either. Any kinda lead would be great. Thank you in advance
