Okay here's the deal with the 02 sensor on an obdII car(1996+,) as it hasbeen explained to me. (I had to design a similar device in tech school, except we used ours to measure heat by way of voltage.)
We start with how the 02 sensor reads, it changes resistance as the exhaust gass passes it. To make a different voltage, (the sensor output to you ECM,) the sensor has to read heat and ground the signal properly. If you've ever seen an electronic air/fuel gauge this is really whats happening. at idle/and low throttle (in town driving.) The car doesn't make enough heat to continue giving the same reading. that's why they strobe back and forth. At Wide Open Throttle (WOT,) The typical car reads .88-.94v varying on what octane/timing/etc.
The rear o2 sensor is for makign a long term fuel trim (part of the adaptive process of OBDII.) Well your ECM knows that it isn't supposed to be a 0 reading (disconnected,) so it throws a code. Well if you weld in a bung for the 02 sensor after a straight pipe, its the opposite end of the spectrum. At WOT the sensor gets too hot makign a higher then normal reading, after the ecm determines it isnt' safe you car then throughs a code causing a check engine light. Usually cars start runnign extremely rich while in this mode. (if you run too rich the car's Exhaust Gas temp is lowered, menaing the ECM is beleiveing its protecting the engine.
I know alot of people who gut their cat, adn etc. but the fact is they may not be doing themselves a world of difference. Most people I know whohave done sop, don't last logn before its back on. The other downfall is you may be making all of 3 HP up top, but that's peak, what did you loose in the low end. if you dont' start pulling in the bottom end hard, odds are youaren't goign to catch up. I told this to a local civic b16 w/v-tech, IHE, lowered etc, no cat. my car which ran a 15.60 at the time ripped him a new one, keep in mind I'm an automatic RS. He was the second person in my town to buy a High flow cat, i was the first I didn't know it would have slowed me down until I put one back on and noticed a better 60'time on all the time slips I had before and after.
(I know its hard to understadn but I'm trying to write better.)
