This 96 integra has been sitting for a few years. The battery is clearly shot. Wanted to know where I should start to get her running again in case the battery isn’t the only issue.
Usual stuff, oil and filter, fuel filter and probably the timing belt. If it starts ok I'd be changing the coolant, water pump and spark plugs pretty quickly too.
Thank you. I’ll try this first then see where it goes from here.
