1 - 14 of 14 Posts
I would like to sell a brand new Drag Gen 3 Turbo kit still in the factory Drag box and sealed. This kit was ordered directly from drag less than 2 weeks ago.
It is for any single cam, RS/LS motor and contains the following:
Drag High flow 4 into 1 cast iron turbo exhaust manifold
Turbonetics T4/T3 TO4E High flow turbocharger assembly
Turbonetics Deltagate Mark II Wastegate (7 PSI Spring)
Drag High Flow front mount intercooler w/
polished cast aluminum end tanks
Greddy Type S Blow off valve
Drag mandrel bent high flow chrome plated pipes
Drag mandrel bent high flow exhaust down pipe
Drag wastegaste dump tube assembly
Drag Blue silicone hose and hose clamps
Drag High pressure/High volume inline fuel pump
Drag Boost dependent FMU fuel regulator
Intake air filter assembly
Map sensor bypass valves
Stainless steel braided oil feed line w/ fittings
Oil return assembly
All nessasary hardware and fittings
All nessassary hose and hose clamps
All nessassary gaskets
Installation manual
The price is 2884.00 is the price of the kit shipped to anywhere in the United States. If you are intereseted please call 206-331-2004 immediately. Due to personal reasons I would like to sell this kit as soon as possible.
Thank you!
Garret
So you ordered it two weeks ago. And now you wanna sell it? *scratches head* May I ask why?
I'm with BlueTeg.....why would you want to sell it, if you don't mind telling? Also, a little side note: Playboy knows what they're talking about!!! Proud to be a Devil here too.
well, being that he/she joind today and only has one post... what does that tell you...
and posted this topic a mere 10 minutes after joining... that includes going to check email to get password and writing this somewhat long post
hmmm...SOHC integra...doesn't sound right...
1 - 14 of 14 Posts
