1 - 2 of 2 Posts
i got a new clutch kit flywheel throuwoutbearing and all that..what is the correct adjustment of the clutch cable and do i have to mess with the pedal? the pedal hight was messed with prior to new clutch
I never adjusted my pedal height just the cable. Make sure to use a stethoscope and you'll need a second person while you tighten and or losses the cable. It's very easy. Put the stethoscope to the transmission bellhousing while you adjust the cable.
1 - 2 of 2 Posts
