I am building a lsvtec and need basemap to get car to tuner about 45 mi away.
b18a block 81 mm
pr3 pistons on pr4 rods
arp bolts and studs everywhere
supertech flat face valves, 85lb springs, ti retainers
skunk2 tuner 2 cams and cam gears
skunk2 pro IM
blox 500cc inj
aem rail
stock fuel pump, regulator, TB, and MAP sensor
demon2/neptuneRTP
aem wideband
hoping someone has same setup using crome neptune or hts
Maybe I'm not understanding correctly. Are you suggesting I use something like a gsr/itr file and drive 40mi on that?
Correct. The only thing you'll need to do is scale the injectors to what you have within the program. Alternatively, your tuner should be able to provide you with a basemap if you already have an appt with them.
