I got a 2001 LS Integra out of the blue check engine light started flashing and it had codes
P0501
P0420
P0301
P0303
P0304
P0300
P1456
P1399
P1456
I put all new
New Both 02 sensors
New idle control valve
New TPS sensor
new spark pluis
new wires
new distributor
clean throttle body
New Fuel filter
After all this its still doing same crap Miss fire 1234 now and then and check engine light comes back on with a code P0132 code and I don't know what to replace next besides buy a new car lol
106989
Maybe do a visual check on the wiring going to the O2 sensor(s), to see if anything got chafed or pinched.
Wiggle some plugs and cables and stuff around to see if the problem goes away/reappears.
Do a visual check on your grounds as well.
I know the O2 is very sensitive when it comes to voltage, so might as well rule the basic checks out in case it's an electrical issue.
is the only codes thats returning the missfire and o2?
check timing/valve lash
