my compressor does not seem to be getting any power to the compressor's plug meaning i cant turn my ac on i checked under the hood for relays they all seem good and i also checked the fuses in the car and no luck. so my question is this.... there are suposed to be two relays for the ac by the compressor i can't find them to check it where are they?
you can bridge two wires to make the compressor turn on...jump the pressure sensor..its on one of the a/c lines closest to the dryer..then the compressor will spin when you turn on your a/c if the sensor doesnt see any pressure it will not turn on thats why you have to bridge it ..good luck
