1 - 2 of 2 Posts
I Have a 92 integ and i'm installing a Faze(yeah i know they suck) Air/Fuel ratio guage, then only thing is is that i need to fine out what color the wire is that goes to the ECU. Some *** told me i need to manually go up under my car inorder to get this thng installed properly, like actually find the black recieving end wire and hook it up to that, but with on a 3 gen you can just hook it straight up to the ECU, can out 2 gens do the same thing, i need some help before install it today.
I hope this diagram can give you a clue of how much help is needed.
(Red wire) ---------------------(positive)
[guage]< (Black Wire) -------------------(Ground)
(Green wire) -------------------(???????)
It's true, you can connect your o2 read wire to the o2 sensor, but have done it on my 300Z(connected to the ecu, and worked just fine)...#24 WHITE wire from your ECU is your Oxygen sensor wire(now remember I did this on a 300Z and worked fine on this car), not the safest, but you can use a wire tap to connect to this wire. Goodluck
1 - 2 of 2 Posts
