1 - 10 of 10 Posts
· Registered
i have the same problem, but my reverse is really bad. i didnt really pay attention to it until i almost ripped my friends shifter out putting his car in reverse...it was so easy lol
i just got my mtf changed and it seems to be even worse. ill change it myself when it gets warmer and use a different fluid i guess.
· Registered
i forgot what kind of fluid, ill find out tomorrow from the mechanic. i think ill try redline or just use honda.
i usually shift to second then reverse but it doesnt always work. i also heard giving it a little gas while putting it into gear will help, im going to try to start doing that. (the 2nd gear habit is hard to break)
· Registered
Gensavestheday on Jul/27/02 said:
yeah, ive got an automatic teg. and if i dont let my car heat up for at least a minute or so , if i put it in reverse the car slams backwards into reverse.. i wonder what that is..
I've got an auto teg too. It does that because when you first start your car it idles very high when it's cold (mine at around 1700 rpm) for like 10 sec. Then it goes down to 700 rpm very slowly (2+ min). It's like dropping a clutch on a manual transmission at 1700 as opposed to doing at a lower rpm.
1 - 10 of 10 Posts
