1 - 11 of 11 Posts
just a happy little report,
about 5k miles ago, I replaced my front pads w/ Axxis Ultimates, process went fine. Then I ordered some axxis pads for the rear and brembo blanks for all around.
When they arrived, I tried removing those infamous rotor screws. I thought I'd be able to take my brand new DeWalt 14.4volt screwdriver and slowly twist these screws out while pushing hard. But nope, started stripping a screw without even trying.
I stopped there and put the wheel back on.
Two weeks later(today) I have my impact driver and attack the previously stripped screw. After several whacks of the hammer, I realize my impact driver was set to tighten, whoops!
Regardless, the stripped screw comes out, phew!
the rest goes well, replacing the front rotors, and rear pads & rotors, one at a time. The rotating rear piston is a strange one. Mental note: when replacing the rear brakes, replease the e-brake! That had me worried for a minute before I realized! hahah!
I put this red brake quieting stuff from Napa, for what it's worth.
The axxis pads seem to make helluvalot of dust!
Oh, the rear outboard pads had a little metal plate on the side. I left them out in the new setup, what were they for?
Impact drivers are a valuable tool. I wanna pick one up one of these days.
Tightening the screw just a bit before loosening it was probably not too bad an idea. The idea is to break a screw loose. once its broken loose, any old screwdriver can remove it easily. Sometimes its easier to tighten a seized bolt then loosen it! If you manage to tighten it so that it turns even just a little bit, it will be broken loose and then loosening it will be very easy. However, if the bolt/screw was severly overtightened in the first place you risk snapping the head off.
the metal part on the pad is there to reduce the vibration on braking... IE making them quieter.... sooo in essence.. no or less squuuuuuuueeeekkkkkssss...lol
Frank
Thanks for the information.
I recently changed my pads as well! I got Ceramix pads so I don't have to deal with all the brake dust.
tdub: I ordered my rotors and rear pads from importrp.com, came to $140+S/H. my front pads came from someone else, about $45. throw in a $30 impact driver, $5 worth of anti-squeak compound, a couple beers, and about two quarts of soap to wash your hands with.
I guess the tightening makes sense, since the screw isnt stripped in the tighten direction. Budge it a little and it'll come out.
Looking forward to the upcoming TreasureIsland meet for some ideas on what to do next!
lol. all it took for me to take out the rotor screws was a metal mallet and a punch. just banged the screws to "shock" them and the came out with the twist of the wrist.
just changed mine 2 weeks ago. Brembo blanks and Brembo pads. all together $152 from www.buybrakes.com
Do you guys just get new rotors everytime you do brakes or do you try to turn them at a local store like pep boys? Is it worth it to turn them or just get $21 bremob blanks everytime?
I get mine turned. I have a shop here that did it for $9 a rotor, so it makes a lot more sense than buying new ones at ~$20 apiece.
1 - 11 of 11 Posts
