Last week I had my master cylinder, the 2 front rotors, the passenger side rear rotor, the rear passenger caliper, and all 4 sets of brake pads replaced. After bleeding the brakes using the RR, LR, LF, RF method, I started my car to check the pressure of the brake pedal. Right after I turned the car on, the ABS unit started to make a whining sound for ~30 secs then it stopped and the light came on. We shut the car off, pumped the brakes some more, then turned it back on. Same noise started again so my Dad added brake fluid to the ABS thing and it's still making that noise. Now everytime I start my car it makes that noise for approx 30 secs and stops and the light comes on and stays on.
Also, my brake pedal still has a lot of "slack" in it. When I press the brake pedal it travels about 60% of the way then begins to stop. I was having similar problems before, that's why I replaced the master cyclinder. My Dad said part of the reason might be that my new RR caliper hadn't adjusted yet so I needed to pump my e-brake. I did that like 50 times and my braking response has improved very little. Is this problem being caused by the ABS system not working?
Btw, I put Hawk HPS pads in the front w/Brembo blanks, thermoquiet ceramic pads in the rear w/ a blank rotor from advance auto parts, and a brand new OEM master cylinder.
